-right off the bat: I know about the fuse under the fuse box area and I know about the pair of relays around the rear washer fluid reservoir - neither of these things are the cause of my problems.
this is an 89 FJ62; I'm trying to understand why the only power lock that works is the driver's door (my gut tells me it's the wiring's age reducing the current to the other solendoids); I haven't yet gone through the other solenoids to measure the voltages they're getting; I do know the lift gate solenoid is good (as I've tested it by hooking it up to a 12v power supply directly). The master switch on the driver's door is essentially new, and since its power lock works (and the power windows work everywhere) I'm ruling that out as the cause.
OK, so before I go totally nuts trying to rewire stuff I'd like to know what other failure points might there be - is there a dedicated power lock relay or another fuse somewhere? I've read a few threads that mention that the liftgate solenoid has it's own fuse but I can't figure out where it would be located.
- let me also add this - when I first got her I had to reset the power lock fuse just to get anything to happen; the driver's door always worked; the front passenger door would lock but not unlock and for the past few months it doesn't even do that anymore; the rear doors and liftgate simply never worked.
