LJ78 with 2LTE- error code 2, 5 and 12. looking for help.
Highlands Ranch, CO
Hi fellow 2LTE wrenches...I miss my LC. I have not driven it since January. Mostly I was out of town. I could not start it in January, therefore, it has been garaged for a long time. It cranks, but no start...not even a puff of black smoke. I thought it was the glow plugs, replaced them. Still the same issue. Checked the error codes:
- 2 (Turbo Pressure signal). Not sure what going on, but this should not stop the LC from starting.
- 5 Correction resister - what should I do? I read that the left is 600 ohms, and the right is 1000ohms. Can I just clean it test the resistance, if good, re-install?
- 12 Timer control valve.
Have you seen 5 and 12 together? What was a remedy? Is error code 5 causing 12 or visa versa? or both need replacement? I am not sure if they are available.
Thanks for the help in advance.
