Hi. I just picked up a 91 LJ78 and I am having a starting issue with it. It is quite difficult to start my car. It has the 2.4L Turbo diesel motor. I live in north of Toronto so our temp drops quite a bit in the winter. My problem is this:
1. My truck is very difficult to start (sitting out for a while). I try to crank and crank and eventually it will catch on with difficulty. I am assuming my glow plugs are weak so I have a set of 4 new ones coming from Austrailia (what is the resistance of a normal glowplug? 1ohm?). There is a little throttle knob on the dash by the right ft of the driver...does it pull out? I understand that it should pull out opening the throttle wider and allowing for an easier start. Mine seems jammed...i cant pull it out at all. I can turn the knob left or right but it doesnt do anything.
2. After I get it to start, I will be off driving for a few minutes. Once I shut the motor off and try to restart it in 30min, it won't start (keeps turning). The second time around it will start fine. Im quite puzzled about this one as it is not a glowplug related issue.
I guess once I get these problems sorted out, I will look into installing a pyrometer and EGT since the 2LTE is proned to overheat at the head.
Thanks ahead for the help!
