Hey Fellas...
So I just have a quick question...
What would be the best way to stiffen up the rear end of the Prado?? I pull a small trailer on a fairly regular basis in town with tools and wood. I know, I know, BE CAREFUL... and I am, but it dosent seem to take much weight at all to make the rear end sag quite a bit. In fact if you put 6 people in their to cruise down to hockey game, that'll make it sag as well.
So, do you find heavier shocks or heavier coils? whats a good price? etc.
I am sure this is a pretty simple question but hey, no harm in asking!
T
T
along with the bags and spacers dberwin mentioned I also installed Airlifts compressor kit to inflate/deflate on the run. It has a pressure switch which will ensure you always have a minumum pressure (adjustable) in the bags so as not to damage them. The pressure gage and inflate/deflate controls mounted nicely just above the "AT temp" warning light under the dash. I put the compressor just forward and above the jack mount behind the LR side panel. You can't tell it's there until it comes on. I also put a tee in the output line with plans to use this for blowing up flats or whatever. (It will supply 100 psi) To complete this I will put in a simple isolating switch and valve.
(eh Wayne?)
