- Thread starter
- #41
Hey Nick, thanks for the input. I had done the clutch fan mod, but am trying a brand new one. Seems to work about the same as the old one post-mod. I do lose a little bit of coolant over time I think, but most of the time I can pour back in from the overflow, and that fills it up. I think it depends how hard I push it over the hills.
I wanted to do most of the GTS mods before I change the head, as I only want to do it once. I next want to remove the EGR system, and will work on larger exhaust this summer.
Just remember, I'm only learning as I go! If you really want a permanent solution that is bar none the best, go to the Evans waterless coolant. After everything I've done, I've realized that is the only sure solution for these engines. You could run it in the red with that stuff and the head will be just fine.
