- Joined
- Jul 6, 2006
- Threads
- 48
- Messages
- 256
anyone know if there is a receiver type hitch available for the LJ78, would like to tow a quad trailer
This is a pic of the receiver that I made (100% custom).
Its a peice of square tube welded thru the crossmember.
The pin that holds the hitch is behind the crossmenber and is vertical. This had the accidental benefit that the hitch cannot be removed when the rear doors are closed.
I also wrapped the crossmember in 1/4" plate as it was quite rusty. I tow my boat with it...bout 1500lb....no problems thus far!
Have you had any issues with it so far? At least for me all I need to tow is around 500lbs MAX. Mine came stock with a hook and to be honest I'm not sure what that's for.On the other hand it is pretty sturdy. I think that for the price is worth a try and if you don’t like it Amazon has a pretty flexible return policy. You guys can be the judge.
