Lj78 Brake bleeding issue. No fluid
Blaine, WA
I just did all new brakes on my lj78 but can't seem to figure out what is going on with this bleeding issue. Rear brakes and front left seemed to bleed fine. Then no fluid from front driver side at all, and now no fluid bleeding anywhere. There seems to be some fluid at all calipers when I take the lines off just not bleeding. There is definitely a lot of air in the lines. Brand new bleeders should not be plugged, and I don't think the driver side caliper is the issue if other calipers are suddenly not bleeding.
We were using the old pumping method so I assumed the MC gave up but I tried taking the lines off of it and plugging the ports and I got good pedal pressure. I switched to a vacuum hand pump now.
I was going to bleed the lspv last. My understanding is that it balances pressure between the rear calipers so I didn't think it would be the issue here. Could I have run into some other pressure issue?
let me know if you have any thoughts, thanks!
