LJ78 | 2LTE | Brake Master Cylinder
New Zealand
I have a quick question regarding a Brake Master Cylinder for an LJ78.
The original part code is 47201-60430. This part is out of production.
I have found the following part but not sure if it will fit the LJ78?
Any ideas / feedback will be greatly appreciated.
That one won't fit, the original Prado master cylinder has a 4-bolt flange, that one has a 2-bolt flange. You might be able to find a rebuild kit if yours isn't too far gone.
Thank you. The main issue is with the reservoir. Cracks are forming all over it and just being cautious. The rebuild kit I can find, but not the plastic container. May need to shop around for separate parts.
Hi @ Nomadtribe...
This is an old post, and I hope you can assist-me with:
I'm looking for a repair kit for the brake master cylinder.
-LJ78 - 2LTE
-Do you have a part code I can use, please ...
Thank you...
Hi @ Nomadtribe...
-LJ78 - 2LTE
Thank you...
Hi @Xando
I can definitely guide you in the right direction.
If you are looking for the rebuild kit minus the reservoir or piping, the part number is 04493-60230.
Other options include wrecking yards or places selling Toyota spares.
There are a few posts with regards to cross parts regarding the master cylinder. I ended up keeping mine as is and only replaced the brake booster.
Hope the above provides some assistance.
