Little cover in glovebox with wires and a connector attached to it keeps falling out
Hungary - EU
Hello!
I have a problem (again:)). I removed the glovebox & the inner cover to get to the antenna relay. After assembling (it didn't go easily, as the middle screw didn't really want to get into place of the inner cover) the little cover with the arrow on it keeps falling out. I believe this is a connector for the air bag? If so, is there a possibilty that I've pinched it somehow with the metal parts that holds the dash board during the assembly of the inner cover? Is this a safety issue? How do I know if it will work correctly? The cables run in a yellow plastic tube, so maybe that has protected it if it would've pinched? Probably just my OCD. The cables are moving freely. Anyway, how should the cables be routed? And why does it keep popping out?
I'm talking about:
55606-60010 COVER SUB-ASSY, INSTRUMENT PANEL UNDER, NO.1
Regards and thanks!
This is the wire & metal bar that worries me - if I was able to accidentaly do any damage to the cable with the lower/inner cover of the glovebox? I can't feel anything on the yellow cover, but it being the cable of the airbag running in it I'm panicing.
Should this lip be on the inside or the outside of the instrument panel (both sides)?
Went back at it today morning with a fresh set of mind. The problem was that the lips should be on the inside, and not like on the picture. Sorted.
My question is. Which way is the arrow supposed to point?
