OK, so we don't all have huge garages like Koffer. Mine is small and filled with crap, but am trying to get as much room out of it as possible....
It's 24'x26' with a 13' ceiling. Only light right now is a regular fricking light bulb square in the middle. Obviously not good enough.
I want to replace that with as many flourescent lights as reasonable (a little overkill is never bad). I've never used flouros at home, so a few questions.
They are ok to use in cold temps right?
No issues with welding by them right?
How many should I get? 4? 6? 8? I want to stick with 4' long ones since the ceiling is high, I have to be able to change the bulbs myself.
Also, plan on making a junction box and having them all run off the current wiring (cause it already has a switch). I figure 8 flouros are about the same electricity useage as a regular light bulb (100W) right? Or wrong? :-[ If I have to add a new breaker, I could do that as I've done that before, but I am trying to save space since I have a few 230 lines in there and a few dedicated runs for the garage.
Thanks.
Thanks.
