I used to run those bushings but they didn’t last they wore out quickly and cracked I’m on a 6” slee lift with slee arms and OEM bushings. It’s been 10 years now no issues.
A lifted 80 really shouldn't need camber correction.
I have used these in my 91 for caster correction. It's a great method that does not receive the recognition it deserves. Next week I am putting a 3 degree set in my 97.
To determine which set to use one would get an alignment and use the alignment numbers to make the determination. If I only needed 1 more degree of caster to be right I would ignore it. I have never heard of anyone actually using the 1 degree set.
The better way to correct camber is use different top kinpins but use standard bearings. Not sure where to get custom kingpins from though. Normally camber should never need adjusting.
I've got some positive camber on my 80. It might be the trunion bearings but I am going to get an alignment and then order these bearings based off how far it is off. My issues are when it is under it's own weight, then goes back to normal when not weight bearing.
The offset bearings give you an opportunity to increase camber and/or tweak caster.
A bit more camber can help with larger tyres by making the steering a bit sharper, more direct which makes up for the additional sidewall flex of big tires.
