Lift With 35's on FJ40
Fischer, TX
I just bought an FJ40. I want to put 35" MT/R's on it, and was wondering how much I have to lift it so it won't rub. Does anybody know that?
Georgia Tech
I would say no less than 4". And that may require trimming the rear fender, maybe not.
Depending on backspacing and width of tire you may also contact the relay rod up front.
3_puppies
Helena MT
spring over will fit 35's just fine
Fischer, TX
Spring over's too much work and too much lift if I don't need it. If 4" will work then I'll trim fenders - If that's all I need.
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
If you center the rear axle, ie re-drill the spring perch on the axle, moving it about an inch or so rearward, you might not even have to trim the rear fenders.
Good luck!
-Steve
Central, Utah
My 40 is SOA with 35s and it just touches under extreme articulation. Petes 40 is +4 with 33s and his rubs hard enough to bend sheetmetal and cut grooves in the tires. If you're gonna spend that much money on tires I'd think you'd want to do it right to protect that investment. SOA is not "too much" lift nor is it that much work. I've done 'em both ways and don't think the lift kit with the required mods to correct the problems is any easier than an SOA. That IS a biased opinion from a welder/fabricator/mechanic who builds a few.
With 35s you better have power steering and disc brakes. Then it'll be lockers, smurfs, cage, rockbox, traction bars, etc, etc,...
Congrats on your new addiction. It never ends. There is always something you want to change.
Jonathan_Ferguson
★ is in the wrong locale
Glen Waverley, Victoria, Australia
Website
Jonathan-Ferguson.tk
Would it be possible to fit 35's on 16x8 2" Back Space with original Suspension and Bump Stops by just cutting the Guards(Fenders :mad:)?
Is Power Steering all that necessary? - Steering is fairly light with 31x10.5 and have no problem at all at Shopping Centre Car Parks. :flipoff2:
Boise ID
My 72' has 35's with stock springs. The rear sheet met. was trimmed. The shackles were 2" over stock. All done by the PO. I added spacers to the bump stops to stop the articulation before the tire got into the fenders, still did rub some. They did fit and it wheeled OK. I am now finishing up the sping over. It is really no that much work. 5 hours on the front with the right tools and it is almost done. I figure another 10 total and it should be running down the road. I won't be into my SOA for more than 400 - 500. L8R
Yakima, WA
For 35's, I'd go with 5.5" minimum lift. Mine with 33's, and a 4" Skyjacker, plus the +1.5" MAF shackle reversal, and 3" BFG KM's the first time I took it wheelin' with just the 4"... did some fender trimming the end of that day, and had no more issues with the rear, but it was close. IMO don't plan on anything bigger than 33's with only 4" of lift.
Website
www.rockcrawler
i don't have a welder. has anyone hired a shop to do the spring over conversion, and how much will a shop charge to do it?
a 4" lift will clear without trimming anything. A SOA around here runs $2500-$3500.
woody
Staff member
Admin
Toquerville UT
Lift springs allow larger tires since they are stiffer/higher rate plus the high arch of a lift spring resists deflection more than a flat spring. IMO, without some tweaks, lifted springs can actually net you less flex than flat stockers, even SUA.
I had some major rubbing on my rig with 4" springs and 33" tires....but I tweaked it a lot for flex. I got rubbing with 33's and SOA too. You'll need some sheetmetal trimming and minor bump stop relocation to run 35's on a 4 lift, but it is a sharp setup.
IIRC, SOA's from a shop are in the $2500 range, done correctly. IMO, buy the welder this year, spend 2004 practicing/learning on other projects, then tackle the SOA yourself next winter. Local Tech schools have great welding classes....I've been taught with assistance from 2 buddies who weld professionally plus a friend who was the Miller Mig division sales guy.
GXO
GXOR
Moderator
Woodstock, GA
Website
gxor.org
After lifting multiple trucks and working on many more I would say that an SOA is the way to go.
I have seen MANY SUA lifts at 4+ inches and the SOA usually breaks down to the same cost by the time you get everything right SUA.
2500-3500 is a bit extreme unless you don't know anyone to work on your junk.
Most SOAs can be done (through connections) for MUCH less.
Cut and turn knuckles-$60
Custom steering (High Steer arms)-$350+ (free if you make it yourself-safe?)
Drive shaft mods-$250
I have the rest already! All the work except cutting and turning the knuckles will be done by myself.
I have a four inch lift right now and the flex is ok, but the spring over is the way to go for more flex. More ground clearance too!
maybe a dumb question.........but why is it when I usually see a SOA the back of truck seems lower than the front. which in my opinion looks like crap. is there an easy fix for that?
longer shackles in the back
Boise ID
cheesy block would fix the sag in the rear. Mine came out even.
Jonathan_Ferguson
Website
There are more Leaves in the front Pack.
