lift kit and shackle question
Williamstown, NJ
Website
www.fj40taz.com
well i finally installed the 4" lift today. at the front of the running board it is 24" and just in front of the rear tire it is 24 1/2".
then the front shackle is stock 3" center to center and the rear shackle is not stock, it is about 5 1/4" center to center.
i would like to get a set of greaseable shackles but i guess i will need different lengths due to the ones i have are already different.
guy i bought it from told me it was done since the chevy was so much lighter then the stock engine so they put longer ones in the rear to level it out.
so question is a shackle that is 5 1/4" center to center equels how much lift??
i've got shackles that are 6" between centres. I forgot to measure how much it came up but you can see the mark in the photo from where the skirt of the shock used to be with standard shackles. the mark is just under 1" long. hope that helps.
Lift from the shackle would equal half of the length over the stock shackle.
If stock is 3", and your extended is 5 1/4", the difference is 2 1/4". That would make the additional lift 1 1/8" over stock height.
To expand on this a bit, think of the spring as a lever. When you raise the end of the lever, the center of the lever (which is where the axle sits) raises by only half as much.
My FJ40 has a SBC in it. With stock shackles and 2.5" lift springs, the rear end was a wee bit lower than the front (plus with 33" tires it would rub the wheel well lip on bumps and hard corners).
So, I install 3" lift shackles on the rear. These were 3" over stock, giving me 1.5" of lift at the axle. This gave the added clearance I needed, and the FJ40 sits with a slight rake in back. Which is good, because it will be almost level with a full load of gear and the trailer hitched up.
