Just about ready to order a Black Diamond 3" lift (on sale) for my 72 FJ40. Will 33/12.5/15s or 35/12.5/15s BFG MTs fit with this lift? If it matters, Im also putting a shackle reversal kit on at the same time.
Dude, i did the same thing with the shackle reversal on the front and add-a-leafs on the rear. No other lift and i rolled with BFG all terrain 33x9.5's. I like the narrow tire since i used the stock wheels.
My dad is running a BFG 33x12.50 on 15x8 wheels with 3.5 inches of back spacing and has UNcut rear fenders. We have had no problem on some pretty tough trails. He is running the 2.5 springs from Spector and they are at least 7 years old. I run with a 2.5 BDS lift and 33x15.50 Pro Comp Xtreme Mud on 15x8 wheels and 3.5 rim backspacing, but my rears are cut.
Hmmm...I think it will be really tight trying to run a 35x12.50. Not much room to flex. Do you have a shop near by that would let you mock-up a 35 on your rig after you do the lift? Probably not what you want to hear, but I've seen so many rigs compared with the same lift and tires and some work great and some others rub.
35's will rub the rear if it's uncut. I run 35's with 4" skyjackers, cut fenders and 8" wide rims and they rub a little on the inside of the rear fenders and full tuck. Good luck.
I like the look of the 9.5's plus they dig really well in snow and mud. Not as wide and dont "float" as bad as the 12.5's which in my mind look way too wide and "fat" for my tastes...
The only reason I use 33x12.5s is for the extra stability from effectively a wider track. In most circumstances I think a narrower tire works better for relatively low-powered high torque engines such as 2Fs & 3Bs, etc. The higher contact pressure of a narrow tire is often (but not always) more effective than the lower contact pressure of a wide tire and is easier on the drive train.
