Ladies/Gents,
I cannot find this info anywhere. I got a backup camera that hooks up to the reverse lights and it mounts on the license plate. Where the license plate sits, there is a piece of trim I believe on the LX 470 that is connected/screwed/etc to the bottom rear door. Is that indeed the case? If so, how is it attached to that? Is is screwed in from the inside (so I remove the trim and get access to the screws to remove it) or is it just there using these plastic clips?
My goal is to only drill (if required) a small hole on the actual rear door, running the cable through the 'top' of that trim piece, ideally not drilling it. Is that possible?
Thanks all!
CR
Thanks all!
CR
