- Location
- United States
1985
380.600 km/236.000 miles
Left Hand Drive, with German registration
Legally in Puerto Vallarta/Mexico with a 10 years RV import permit, valid until September 2024
I own the car since 2004, previous owner was a German car master mechanic
who always looked very meticulous after the car.
3 B Diesel engine + Garret Turbo Charger + Intercooler, EGT and turbo pressure gauges.
(installed with 255.000 km)
Engine runs very smooth, like the transmission – HF 55
No oil consumption, no oil refill between oil changes!
Aussie Locker Diff Lock in the rear Diff, LSD in front Diff
Full Floater rear Axle
2 Tanks, Original 90 liter + 140 Liter long range tank (disconnected at the moment)
+ extra pump to pump from rear into main tank, total 230 Liter/60 Gallons
Adjustable extra air suspension (Air Lift) on rear axle
Air Lift Company - Tow and Haul with Safety and Comfort
24 Volt Compressor behind driver seat
Belt driven truck compressor with extra tank in engine compartment with connector,
with magnetic clutch and switch inside the car
Vacuum operated truck exhaust brake system (Nissan, sorry
Power Steering
powder coated original Toyota 16 “ steel rims (very sturdy) with 265/75 – 16 “ tires
(front 85 %, rear 40 %)
30 mm Aluminum spacers on all wheels (Made in Germany)
2 adjustable orthopedic seats “König” (Made in Germany),
with extra space under the seats for tools etc.
2 special safety locks on each door
HID Xenon lights
Front tubular construction can be removed in aprox. 1 hour
Full travel/camping configuration:
Special Mobils pop up roof, Made in Germany
(special mobils Produkte Hubdächer)
2 x 40 Liter water tanks (80 Liter/21 Gallons) running with Shurflo water pump + plus new Shurflo spare pump
24 Volt system with 4 batteries, 2 for engine (2 years old) + 2 for internal consume - these need to be replaced
2 x 85 Watt Solara (Made in Germany) Solar panels installed with extra charger,
full working
24 V – 220 Volt sinus inverter installed (charges all laptops, tablets or cell phones)
Inverter - Powersine 300W – 800W (12V/24V/48V) - TBS Electronics
2 x 24 V – 12 Volt inverters + new spare inverter (Made in Germany)
Garmin GPS Map 267 incl. external antenna and extra speakers in the ceiling for the announcements
Eberspaecher Diesel heating system (Made in Germany) - (disconnected at the moment)
Eberspächer - Exhaust Technology, Vehicle Heaters, Automotive Electronics
Special bumper bar with 3 storage compartments and entry for High Lift (as well rear bumper)
2 plate gas stove incl. gas tank
stainless steel sink with faucet
National Luna fridge, one of the best brands on the market (in my humble opinion)
runs with 12 Volt, 24 Volt, 110 Volt and 220 Volt
NL 40 Stainless Steel Refrigerator & Freezer - National Luna
wooden furniture with a lot of stowing room and sliding table, inside the car.
3 high quality latex foam mattresses which together make the bed for 2 people
Can sleep 3 people, 2 up and 1 down.
Pioneer Stereo MP3/CD radio with external USB port + High End Focal 2-Way-Speakers (France)
Original High Lift Jack with extension for rim
Hand Winch stored in an extra compartment on passenger side with steel cable
Chemical Toilet “Porta Potty”
2 Original Toyota workshop books, 1 for the engine and 1 one for body and all the rest of the car
. . . and many spare parts are included . . .
Info about maintenance:
Repair Clutch Master Cylinder, 380.300 km
Last Oil Change 379.900 km
Last change of diaphragm from injection pump, 374.000 km + spare diaphragm
Last Front Axle overhaul, including all bearings, bushings, seals etc. 372.000 km
Last transmission and rear diff oil change, 364.000 km
Rear Diff and Axle overhaul, including all bearings, bushings, seals, 338.000 km
Alternator complete over haul (coil, carbon, bearings, rectifier) 333.000 km
Last clutch change (AISIN reinforced), 320.000 km (measure of precaution),
+ spare used, but still usable clutch
Complete Starter over haul, 320.000 km (measure of precaution), spare 24 V starter
New water pump, 320.000 km (measure of precaution) + spare overhauled original Toyota water pump
Diesel injection pump over haul incl. new injectors, 320.000 km (measure of precaution),
+ new spare Denso injectors
New clutch slave cylinder, 320.000 km
Brake booster overhaul, 320.000 km
All fuel (diesel) hoses were changed in the last year
I sprayed an oil-grease mix in the whole body (drilled some extra holes and closed them with rubber plugs).
The whole frame got manually cleaned and 5 times painted 8 years ago.
The awning from the roof is not in the best shape. This can be replaced.
Some rust. Can be removed and painted again
Pop Up roof could need some new gas pressure springs. Complicated to get in Mexico.
Usable without springs as well.
Some indoor fairings on the back door are not in good shape
Rear axle has a patch since about 9 years.
It was a bit humid at the welding seam, not leaking!
The truck is in Puerto Vallarta/Mexico. This is a popular tourist spot for Canadians and US Americans.
See Your Own Personal Sunset at Puerto Vallarta | Official Tourism Guide
There are flights from all mayor cities in Canada and the US to Puerto Vallarta.
I sell the truck because we actually nearly don’t use it anymore (no time).
And it’s a shame to go only shopping to Walmart and not on an adventure with THIS truck.
I am asking 29.999 USD
If you are interested send me a message or an e-mail to
cruisertravel(at)gmail.com
We could arrange as well (video) phone calls with Skype or Whatsapp
Power Steering
HID Xenon lights
full working
