Lexus LX - Land Cruiser 100 Window Pinch Sensor Reset
The auto up doesn’t work at any position. So unlike the other windows that do work, the drivers switch light is blinking and does not auto up or down, in any window position. The window will bump up or down if I try to use auto but the automatic doesn’t kick in. Make sense?
Yes, pinch sensor reset will not fix this problem.
Just did this job today on my passenger rear window which had the 'hits the top then bounces back down' syndrome when using the auto function. I hadn't heard or seen any mention of people doing this or even a regulator/motor replacement on a rear door, so I wanted to chime in with my experience.
I did not remove the glass, I instead taped it and used wooden prop rods, removed the 4 regulator mounting bolts, and pulled the regulator out with ease. On the bench the rear regulator has no spring, so just pull the motor, run it a few seconds, then reinstall. One thing that I got hung up on is clocking the motor to the regulator gear—the motor needs to be one cog back from maxed out even when the window is all the way up. Hopefully that makes sense when you see it.
Overall, the job was much easier than I expected, the ability to do this without pulling the glass was a benefit.
Window is working great, so I'm happy!
Just replaced my smashed passenger front window and this is the top I needed. Thanks for the post.
This was the first result on Google when I tried "pinch sensor + ih8mud". Well done @Kamran Khan . A few points:
* Can confirm this does fix a bad pinch sensor on a 2003 LC rear passenger window.
* The "lost footage" part of the video is all you need to know. Run the motor UP for 4 seconds and you're good to go.
* You definitely need to separate the motor from the regulator per Kamran's other messages. Without the glass the pinch sensor still activates. Try it and see!
* Do yourself a favor and completely remove the plastic wrap, vs. fighting it like in the video. It's also stated in the FSM.
The last bit of advice is to have no fear. Probably at the "medium" of body-related work. You can do it.
