Let's get this gas mileage thing down!
Discussion in '80-Series Tech' started by livelarg, Jun 30, 2005.
  1. livelarg
    livelarg
    325
    Media:
    22
    Albums:
    1
    37
    May 11, 2005
    OKLAHOMA cITY
    All right, I have a 92 cruiser' with 210K miles.
    I have read about peoples different cruisers, and i have heard that some people are getting 13-16 mpg, while others, including myself are getting under 10 mpg.
    So this in my question. I know I have many miles, but what do you think the reason for such different mileage between trucks?
    What are some ideas that would cause for a dramatic loss in mileage. I have done a full tune up, I do have some 32x12.5 off-road tires, but I am getting 7-9 mpg.
    What are ideas to make it better?
    All right, lets hear it
    Kent :confused:
  2. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    Get a Honda. :flipoff2: No but seriously I have never heard of getting 7 miles to the gallon with 32 inch tires. Are you sure you aren't putting some homebrewed stuff into your tank?
  3. livelarg
    livelarg
    325
    Media:
    22
    Albums:
    1
    37
    May 11, 2005
    OKLAHOMA cITY
    I wish that was all it was.
    Hell, my truck will get just about anywhere, as long as there is a gas station near it.
  4. Fly Rod
    Fly Rod
    3,061
    46
    May 23, 2005
    Ashland, OR
    Shoot, I wouldn't know! My stock 95 got 16.85 mpg over 700 hwy miles. Around town is running @ 14mpg.
    Try a clean air filter, new plugs and wires and synthetics all around. Some engines respond to different oils with increased mpg. How old is your cat?
    Just throwing darts.
    Fly Rod
  5. IdahoDoug
    IdahoDoug
    8,864
    272
    Aug 9, 2003
    Did you correct the MPG for the larger miles??
    DougM
  6. Silicon 70
    Silicon 70
    815
    5
    Feb 12, 2005
    Hollister, CA
    How about cleaning your fuel system. Try the pure techron stuff that'll treat 20 gallons, it's like $10 at the auto parts store. Oh and treat it twice this is the key.
    I have a 92 FJ that runs smoother and gets 4-5 more MPG after doing the fuel treatment, but then again I'm running stock tires.
  7. livelarg
    livelarg
    325
    Media:
    22
    Albums:
    1
    37
    May 11, 2005
    OKLAHOMA cITY
    I ran the seafoam through the gas and the whole pvc valve thing, not much better.
    The cats are prolly the originals, the only other thing that I didn't do is the o2 sensor. That is next on the list (they are pretty pricey).
    thanks for the ideas,keep em' coming
    kent
  8. whodat
    whodat
    679
    Media:
    1
    Albums:
    1
    596
    Sep 13, 2004
    planets
    livelarge, Doug made a good observation. Your calculations could be incorrect because your speedo thinks you're going slower than you actually are.
  9. Boston Mangler
    Boston Mangler
    3,589
    5
    May 21, 2004
    San Diego
    I had a 91 with around 95k that was all tuned up, synthetics and stock tires and i averaged 9-11mpg.
    I now have a 93 and will be seeing how that does as well soon.
    Proper tire inflation also helps out more then you might think!
  10. whodat
    whodat
    679
    Media:
    1
    Albums:
    1
    596
    Sep 13, 2004
    planets
    in other words...the odomoeter measures less miles when you have bigger tires.
  11. MaddMatt
    MaddMatt
    74
    Aug 25, 2004
    I think you've got an issue somewhere. I have an '89 3FE with 230k, a spotty previous owner history and running BFG 32X11.50's, and I routinely get 14+ uncorrected, about 16 corrected. I determined at one point that my tires are about 13% larger than stock.
    I drove a round trip of nearly 500 miles on tuesday, including two passes near or over 11,000 feet, and still got 14.5 (16.38)
    I don't know where to tell you to look, but something is definitely holding you back. Since you just had a tune up, we'll assume your filters are clean and plugs are new? I believe in '92 you're still running the 3FE, correct? I would suggest going through the miles of vacuum hoses and looking for a bad one. Every time my engine starts missing or running roughly, I've been able to trace it to a bad vacuum hose. Good luck.
    -Matt
  12. Romer
    Romer fatherofdaughterofromer Moderator
    11,058
    2,678
    Sep 14, 2003
    Centennial, Colorado
    I believe Doug means larger tires :D
    My 285's are about 6% over stock in size, so when I figure gas mileage, I take whats on the odmeter and multiply by 1.06 for the mileage to use in the calculation. That would not explain your difference though
  13. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    mine here in the UK done 560 miles on two full tanks of fuel, work that one out?
  14. chiz45
    chiz45
    164
    19
    Mar 27, 2003
    96 cruiser, 119k, no speedo correction, stock gearing, 285/75/16, 225 miles on the trip meter = 20 gal fill up (and $50 poorer). Using Romer's figure, it should read 240 miles. That works out to about 12 MPG mixed city/hwy. I have never taken it on a trip far enough to measure solely hwy miles.
    Would different octane gas have a noticeable effect?
  15. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Right, but fj62s came with 28s, and the 80s came with 31s. BFGs run small, so IMO his correction would be minimal. Use a GPS to figure it out.
  16. White Shark
    White Shark
    763
    Media:
    1
    Albums:
    1
    4
    Dec 13, 2004
    Red Triangle
    My stock 92 was pulling 14-15 mpg with the original size/style tires and 110K miles. Around 200K miles, OME lift, ARB bumpers, 33" M/T tires, etc. it was getting 10-11 mpg. With the Chevy 350 and a Kaymar roofrack and tire on the top, I'm getting 11-12 mpg. Without the rack and tire on top, I figure I'd get 14 or so.
  17. gorister
    gorister
    92
    Mar 2, 2005
    Costa Rica
    My 91 with 31x10.50's consistently sees 9-10mpg for normal daily driving (10% interstate) and about 14mpg over 200 miles of interstate driving. 170k miles. Does that sound about consistant?
  18. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    so on a full tank, standard car, what is the usual miles you would get from full to orange light? I get 280 miles
  19. Jim_Chow
    Jim_Chow
    2,479
    14
    Apr 28, 2003
    Turquoise Trail, N NM
    Even if you're using the correct gears for the tire size, most likely, the speedo is off. Best way to test it is to calibrate your speedo vs. the interstate highway mile markers over a reasonably long distance (say 10 miles or a multiple of ten...the more miles, the less error). You can then determine how your speedo is reading. I found my odometer/speedometer reads 2.5-3% higher than actual, so I have to subtract that off my calculated mpg.
  20. TomH
    TomH SILVER Star
    963
    129
    May 14, 2003
    Seattle
    I grabbed this from another thread.
