SOLD Lets get this done: SoCal 1996 FZJ80 Built (1 Viewer)
Year
1996
  1. 80 Series
Mileage
235000
Color
Green
1996 FZJ80
235,000 miles
ARB Deluxe with V10 Warn Winch/synthetic line (used only several times)
White Knuckle Rock Sliders
Sean Rear Bumper Dual Swing Out
ARB Full Rack
OME Heavy Lift
Setup for dual batteries
Light force lights at the front.
Unused 33" Nitto Terra Grappler on the bottom.
No heavy damage, just pinstriping.
Been religiously keeping it lubricated with 10w30 mobile 1 synthetic every 3000-4000 miles.
But due to the leak its leaking 1 quart between, which I've been topping off.
Things to note:
Driver side exterior door handle is broken.
Rear hatch handle doesn't work, need to open from inside.
It isn't in the best shape.
I removed the back row and third row seat. and there is no carpet.
Front seats are torn,
The Front Bumper has surface oxidation.
Front Hood was sprayed with rhino
ABS has been removed
Oil Leak. I think from front oil pump cover and I think rear main.
The sean rear bumper needs a little work. One of the stoppers snapped off, but it is still 100% functional. I used a large hex key to keep it open.
Currently the swing outs are removed, but I got all the bearings and nuts to put them back on, they've been sitting in their own oils so they aren't dried up.
No cancer as far as I can tell.
Edit: Steering wheel is melting off little by little.
Dash has a crack.
Definitely a project or parts truck.
We used to go on a lot of trips with this rig, but switched to a Van set-up.
Since we switched to the van set-up, It was used as a DD for a few years until about 6 months ago and it has been sitting for about 6 months. Definitely has degraded to a project/parts truck.
This will come with extra parts, brand new front rotors, used starter, front runner spare tire steps, a 6th nitto spare attached to a different wheel though, but will fit on the LC wheels, extra parts and tools, etc.
The roof rack is separated and the dual swing outs are separated. Will give preference to whoever makes my life easier. Make an offer.
Not letting me attach more than 5 photos. The gallery is below.
Lockers? Interior color?
Your inbox if full. I’m in NorCal and interested. You can text me 9164501137 Dennis.
