I pulled three of the four bolts holding the LSVP bracket to the frame to gain the fraction
of an inch needed to remove the bolt, but I can't seem to removed the fourth bolt holding the bracket without dropping the fuel tank.
Is this Correct?
The FSM doesn't mention any issues, just says to remove the bolts.
I'm thinking real serious about taking an angle grinder to the offending portion of the bracket.
I can tell you one thing, when I put the bolt back in, the nut is going toward the LSVP.
Is this Correct?
