15 LC. Changed my high beams to LED with anti-flicker modules (diode dynamics). Happy with the lights. Bright and great color. A little more spill off to the side lighting up the signs than I'd like but thats ok.
So here's the issue. Probably happens with all LEDs. When I turn on DRL, I get high beams full blast. Is there a way to get the LEDs dimmed in DRL mode? Anyone know if LC DRL is PWM or voltage drop? I'm guessing voltage drop based on the LED function.
Diode Dynamics said:The SL1 will still be the same cool white color when functioning as a DRL. I would verify that your DRLs function on a PWM (Pulse with Modulation) signal, as opposed to a voltage drop. Our SL1 will only dim properly on a PWM signal.
