Led 60 tail light replacement( full led Housing not just bulbs) (1 Viewer)
Houston Tx.
Any one have the digi tails led tail light replacements? Wanted to here some feedback ? Or is there any good replacements that I'm missing?Left rear is broken an was thinking about switching to for brighter lights
Tailight and especially reverse light LED's are a great improvement. Easy to find 1156 and 1157 bulbs. Get colored bulbs for each application or the lenses will look faded.
My experience is that turn signals aren't worth the hassle because you have to mod the flasher.
superbrightleds
Replacing the dome light will change your world.
That is what I did. The flashers are a hassle. I did the pFran projector led reverse lights and they help a ton.
Anyone having an issue with LED installed tail lights flashing when turn signal is on? I saw someone else had an issue on a post from a few yrs back, but didn't see a solution. I'm running incandescent in the turn signals (didn't want to deal with the load resistor), but seems like it's still causing an issue w. the taillights.
Thanks!
