I've been thinking about getting airbag helpers for the rear springs. Reason being that I really like my rear TJM progressive springs - great flex, great unladen ride, etc. - but they sag pretty badly under load and I do tow with it from time to time and/or put a lot of people and things in it. I has questions for those that have dabbled in this world. And no I don't want constant rate heavier springs, I'm unloaded and commute in it most of the time.
Questions -
I know you have to remove the bump stops.
Permanently (cut out) or can they be re-installed?
Are there are worries about bottoming out with the stops removed? Seems like you would have to choose between bottom-out resistance and up travel since you would need a given amount of air to prevent bottom out that maybe wouldn't allow the coils to go to full stuff. And it seems like you would change the progressiveness of the end of travel rate.
Do you get load support only (bring the ride height back to level) or ride height changes as well? I.e. if I went with independent air valving (which I would like to) can I actually change the height of one side to level it out at camp? Or lift the butt a little extra for times when departure angle is key.
Is there a good reason NOT to do independent vs connected air-lines? I realize I would have to be careful to fill them evenly most times. Alternatively, can't I just install a crossover valve that would automatically balance the pressure, then close it for ind. control?
How do they affect travel? less flex?
How reliable are the connections? I hear some people are constantly messing with them for leaks.
I feel like airbags would give me everything I want - variable load, constant ride height, camp leveling, compliant unladen ride, etc but I'm a little wary about the bump stop thing in particular.
Anyone have insights into installing these? I was looking at the Airlift 1000 from the airlift company. I was looking into their kit for full ind. control with compressor but thats probably more than I want to mess with.
Questions -
