Leaky Injectors? Osidetiger 4 hole installed
SUMMIT CRUISERS Jr
Norman, OK
Over the past several months, an injector leak stared to develop. I was worried because gas was dripping down above the exhaust. I ordered Osidetiger injectors after talking to a guy locally who went with these injectors on his 3FE powered Fj62, and new gaskets from @cruiserdan
We started taking apart everything at 9:30 in the morning and finished the install 10 hours later.
This was the most disassembled this engine has been in its 361,000 miles. While apart, we cleaned the fuel rail, injector cups and all little parts in there. We also tried removing most of the already deactivated EGR stuff, but couldn't find the caps needed locally.
New and old
New is on the left and old is on the right.
Using an oring lube on all the injectors, and dielectric grease on the connections. All the old plastic ones were just breaking to piece when we pulled them off, so we used zip ties to make sure they wouldn't come loose.
The install went pretty good until tightening the intake back down. Using a torque wrench at the required spec in the FSM, one tired bolt just broke before it was tight. I would recommend buying new bolts if you are replacing injectors/gaskets to save a lot of headache.
The truck seems to start up smoother and quicker, and also has a little bit better throttle response initially. It also seems to be smoother while idling. Haven't driven it much since the install, but hopefully fuel mileage will stay the same, if not improve.
Clean rust-free engine bay. Are new fuel injector harness connectors still available for your FJ80?
SUMMIT CRUISERS Jr
Norman, OK
Those injector connections look a lot like the FZJ to me. I'd wonder if they are the same.
No idea if they are the same. They do look similar though.
These injectors came with the wiring plugs. All I had to do was plug it onto the injector and back into the factory wiring loom connectors...which every single one of them broke when pulling out the old ones.
After driving about 50 miles of highway, these definitely feel like they have added more power higher in the rpms. Fuel mileage over that 50 miles seems pretty good so far.
Aggiesdm
***** Regular
San Antonio, TX
Was wondering If you have an update on your milage and performance? My 3FE is getting less MPG and thinking about replacing or reconditioning the injectors.
Also, how much did the new injector setup cost?
SUMMIT CRUISERS Jr
Norman, OK
I definitely feel like performance is a little better. It definitely idles smoother and seems to have just a tiny bit more power at higher rpms. Over my 600 mile trip last weekend to the Ozark National Forest, I got 10.95 mpgs (corrected for tires/gears). I know it isn't much, but loaded down with two bikes, gear, a rtt, and really pushing the truck to get there quickly, I am pretty pleased. Most of the time, I was running 70-75mpg and even 80+ in some places.
It pretty much seems to have given me 1mpg more than what I used to get.
If I remember correctly, the injectors were just below $200, and about $100 for new gaskets and small parts from @cruiserdan
Aggiesdm
***** Regular
San Antonio, TX
Thanks a lot. Appreciate the update.
cruisermatt
Un-manufacturable
Orlando Florida
Just installed these along with my newly rebuilt 3FE in my FJ62, haven't run it for more that about 10 seconds or so, still dealing with a mega fuel leak on the col start rail. For any 80 owners that didn't see the thread in the 60 section, this will be a much easier install on a de-smogged rig with the air injection manifold plugged. I wrapped each connection on the wire harness in electrical tape, but every harness I'be disassembled (a few) has had the injector connectors fall apart.
For injector recon, I use a guy here who is known nationally. He charges $15/injector or so. He puts them in the test jig and measures their output for a "before" chart. Then he cleans them professionally with chemicals and ultrasonic and physical means. Then he replaces all the seals and O rings and measures the output. If one is out of spec, he can tune them slightly to get uniform output, then includes an "after" graph. His business name is "Mr. Injector" here in Coeur d' Alene, Idaho on Government Way. He's a great guy and this is all he does. I have had every single one of my project vehicle injectors done by him and each one had an obvious improvement in engine smoothness, starting and economy even though they were all already in a fine state of tune. it's kinda cool watching how bad an ordinary injector spray pattern looks, then how tasty and uniform it looks afterwards. Highly recommended.
DOMINICAN REPUBLIC
New and old
I got a question dude.
Respect the third pucture, im watching a kind of adaptors on the top of this injectors, this came with the kit? Im looking forward to buy this injectors. Thanks!
SUMMIT CRUISERS Jr
Norman, OK
I'm not aware of any adapters. In the third picture, the new injector is on the left and that is exactly how it came.
Spokane WA
Are you still running these injectors Summit?
I had them on my H42 truck but I only put about 5k on them before I sold it. Wondering about the longevity, even though I am probably just going to have my current ones serviced.
SUMMIT CRUISERS Jr
Norman, OK
I think that hes referring to the jumper harness between the injector and the truck harness
He hit me up on Instagram and we got it sorted. He was just talking about the seal on the injector.
Yeah I am still running them. My cruiser is now at 426k miles and no issues.
