I am finishing up a frame swap and was wondering if anyone had any tips on sealing up a leaky collector gasket (where the header meets the exhaust pipe). I had to separate the exhaust to pull motor. I fired up the engine for the first time since i did the frame swap...
I bought an aluminum 3 hole collector gasket from a local parts store,, tightened it up and it doesn't seem to be sealing tight,, there are some obvious leaks. I don't want to tighten the bolts so much that it bends flanges... The collector kit came with 2 collector gaskets. Should i run them both? or do i tighten the hell out of them? or tighten, let the header heat up,, then tighten again? Thanks in advance... Silly question,, but couldn't find a good answer...
