Leaky front And rear seals
Gainesville, FL
Before replacing these, do any of those seal swelling additives actually work without causing more harm than good?
tarbe
Houston, Texas for now - Romance, MO soon!
If you are going to replace the seals anyway in the absence of an improvement, then you have nothing to lose.
You can also try AutoRx or an oil with a high ester content. Most so-called Hi-Mileage oils have esters that condition seals.
Irving, TX
I had a slight leak at the rear main last spring. It was just enough to leave a drop on the garage floor if the truck sat for a couple of days. Switching to Mobil high mileage oil seems to have stopped the leak.
powderpig
Boulder Foothills, CO
It may be the pan arches, you may want to take a mirror to the rear one and see for sure. As for the front one remove the stone guard and take a real good look at the seal and arch and see which is leaking. later robbie
