leaky FJ62 tranny
Mebane,NC
So i have an ATF leak at the front of my tranny that seems to be coming from the lower inspection plate, It drips out a circle about 4 inches when I stop driving it and then stops, the outside air temp here just started getting up in the 90's around the same time the problem started.
any ideas on what this might be would be great.
thanks
I had a similar issue, I had to have a new seal put in where the transmission meets up. The Trans shop said it was where the torque converter mounted. Took care of the problem though.
Had the rear Main seal done at that time as well.
Expensive if you don't do it yourself.
Thanks for the input now i know where to start
Did you think your TC was leaking? Also, where are you picking up your tranny seal at? I am looking at the same thing during my rebuild...
