Leaking oil along passenger side running boards. (1 Viewer)
Has anybody encountered this issue and have a fix? The AHC fluid doesn’t seem to be affected and no leaks around the accumulator or AHC lines. Is there a leak covered behind the running boards?
Check AHC and brake fluid level in reservoirs. Be sure to check brake fluid as directions on brake reservoir. Top and watch level in each if low!
Brake reservoir
The oil runs through the front passenger somewhere and drains through the channels to the back. Does anybody have any idea how this is happening? I hope I don’t have to tear down the dashboard to see where?
The oil is light brown that I can’t distinguish between AHC vs brake fluid. So does the heater core have oil fluid ?
Really not sure. But by the time the fluid you’re seeing runs along the channel, I’m sure it picks up all kind of junk making it undistinguishable.
Maybe try parking the other way and then see where the fluid goes.
I just don’t see how an external fluid like ahc or brake fluid can enter the cabin. I also don’t know much 😂
Perhaps a passenger's Mr. Pibb they failed to mention??
Fluid level will be your best clues! i.e brake or AHC reservoir.
Also consider the possibility you drove over some liquid that splashed up there.
In any case clean and watch.
Update: I finally found out this oil was leaking from the rear passenger seats hydraulic shocks. Oil puddle onset the seat locks. This oil is now gone and no longer dripping.
