Leaking from front of Engine (1 Viewer)
west virginia
Anyone have any ideas on the origin of this leak? Main seal or something else?
Most likely front crank seal and/or oil pump cover gasket.
^^^This^^^.
Prvbs: try a search for these terms in this forum: oil pump cover leak
Lots of tip and tricks in that thread
Ok, did it for you:
Here's a video also:
May also be the distributor O ring but, more likely - power steering fluid reservoir. CDAN will have nailed it but, with the mileage and age, my money is on more than the one or two locations. Before jumping in, get is steam cleaned. You will then be better able to find the sources and, working on it will be so much nicer. Spend the money, get it done first. You can thank me later...
