Leaf springs popping out of bracket?
Aspen, CO
Noticed this today while I was doing some work on my rear brakes.
Apologies for the poor description (leaf springs popping out of bracket?), but I really don't know how to describe it. The picture included below should be pretty self-explanatory.
My questions are: how big of an issue is this, and what is the best method for fixing the problem here?
Any help is very much appreciated.
The leaf pack clamp (or whatever it's called) is there to keep the leafs aligned in a bundle. Keep an eye on it. If the top leaf doesn't get out of whack with the rest of the pack, you're fine. Does it look like an extra leaf was added to the pack? That would explain why the clamp doesn't fit any more.
I think an add a leaf is responsible. You can get a generic spring pack clamp at most auto stores that would keep them in a stack.
It looks like you can slide it rearward 2” past the end of the 3rd leaf. Hammer it back together.
Not quite.
That clamp is riveted to the 3rd from the bottom leaf and can't slide forward or backward.
Looking at the rubber isolators, it appears that the spring pack is original, no add a leaf.
As far as why it is deformed and no longer doing it's job... too many miles is my guess and time for a suspension overhaul.
And a new muffler/tailpipe too.
I was going to say the same thing, like someone bent out the stock clamp after adding a leaf or modifying the pack in some way.
Thats what I did when I added a leaf and it looked 110% just like that, if you look at the arc of that 90 it would br perfect with one less leaf.
Hi, I would says the springs are inverting, you need new springs. Mike
Thanks for all the replies. I've had this cruiser for 10 years. It's possible a leaf was added, but I don't think so.
Upon further inspection, I saw that the bracket is actually cracked on the bottom side.
Ultimately, I think I just need new springs. A small lift has been on the list for a while, I'll treat this issue as a forcing function and get it done.
Thanks again.
PC
