Leaf Spring seat question FJ60/FJ62 (1 Viewer)
SHERMAN FJ62
Charlestons' King of Cruisers
charleston
My rear psg side leaf spring seat is damaged and rusting our. Can’t seem to find a FJ62 one. Is there any issue with using one from a FJ60. Sorry no pictures but the general shape is similar but the FJ62 seat seems to be better built.
Houston, the lower bowel of TX
The FJ62 rear passenger side spring plate is different. The shock mount pin is offset (longer) towards the front of the vehicle, the pass. rear shock actually sits more forward than the rear d-side shock. This is to accommodate/match the forward dogleg in the upper shock mount tube on the fj62. Why the dogleg?....looking at it I assume it is to make more room for the fuel line routing on the 62 coming out of the gas tank.
Don't think any of the 60's have this offset...correct me if I'm wrong.
You can use the 60 plate, but your rear shocks will be working at slightly different angles to each other. Does it make a difference? could it be a little harder on the bushings?...maybe, don't know.
I went through this recently trying to fit a ubolt flip kit on my 62, I opted to keep it stock in order to keep my shocks working in the same plane.
OSS
Oblivion
You'll never be able to match the ride height side to side by installing one used spring. It's not going to match what you've got (due to different wear) and one side will lean.
When one spring is shot, both should be replaced (if you want the cruiser level).
SHERMAN FJ62
charleston
I am talking about spring seats Or the mounting bracket but I appreciate the info
  • Like
Reactions: OSS
NYC
Hello everyone
any idea where in the US i would be able to buy front and rear leaf spring for FJ62 with the original specs, not lifted
Thank you very much
PS: I am new here, first time I am asking a question
Boulder, Co
Hello everyone
Thank you very much
I think SOR.com carries a grocery go getter kit for the stock ride height. It’s not cheap at all when compared to the lift kits. But if it must stay factory that’s probably your best option. Either that or find a suspension shop that makes custom springs and have some fabbed up.
Oh, and welcome to mud! :flipoff2:
