last call - 2F emissions parts + a few more (1 Viewer)
Purcellville, VA
Only a few smog items remain
- spaghetti pipe (10.00)
- HAC Valve (15.00)
- Air Bypass Valve ($75.00....stupid expensive on SOR)
the others:
- very nice set of stock OEM caps (front and back) for stock 15" wheels (75.00)
- very nice set of stock steel OEM wheels (x5) ($250.00/5) off an 85 FJ60.
I guess the manifold swap went well? I hope so...
All desmogged now?... I hope the truck is registered (inspected) elsewhere cause you would need that stuff here in NYS to pass inspection...
I'll take the following:
- EGR cooloer (10.00)
- EGR pipe (5.00)
- flexibe EGR pipe (5.00)
- EGR modulator (20.00)
- air rail (with all ferrules and nuts - all good shape) (20.00)
for a total of $60. Let me know how to pay. email also sent.
PM sent on Smog Pump
only a few things left.
HAC Valve (15.00)
Do you think the HAC valve was working properly? I don't think mine is. If so, I'll take it.
Also any of the ABV hoses you have (I especially need the one from the ABV to the air rail and the one from the ABV to the smog pump).
Did you sell the check valves (one is pictured on the top of the air rail in the picture- it screws on and attaches with a hose to the ABV). The other one is on the end of the long exhaust tube from the ABV to the exhaust below the brake booster.
Do you have the Vacuum switching valves (I specifically am looking for a VSV1 for the ABV). Your description says ASVs, but I'm not sure if that's what you were referring to.
Thanks.
Do you still have the wheels? If so, what is the diameter, width, and backspacing?
Thanks!
