Lack of drive on hills
Australia
I have a 1HDT auto 80. When out wheeling if I go to drive off from a stand still on any incline/angle, the revs will not go over 1200RPM and there is no drive. It doesn't happen all the time but enough to piss me off. The motor, turbo are all fine, the injectors and fuel pump have been rebuilt, No mater if the gas pedal is flat to the floor the rev's don't get any higher, put it into N and the revs are back.
Help me PLEASE
Any Ideas?
Thanks
Help me PLEASE
Any Ideas?
Thanks
Can you hand throttle it by pulling on the lever at the fuel pump? Was it there before the pump rebuild?
yes, the problem was there before the rebuild of pump, injectors and the replacement of the turbo. it is a little sluggish of the mark, but I'm getting used to it but when your out wheeling and you stop behind someone and you go to take off ......yeh:censor::censor:
I would check out the TPS. I have seen two similar cases like this on a TD4.2 - lots of revs while parked but put it in gear and bounce it around and you get nothing over a high idle speed. In one case it had to be replaced because it was on an auto (needed for the tranny to work) and in the second case on a standard the owner just removed it. On the Bosch rotary type pump, you will find it on top. I don't have a clue on how to test these things but maybe Rosco knows.
Help me PLEASE
Any Ideas?
Thanks
check your gearbox/torqe converter oil levels
levels are fine, check that once back on the flat
It does seem like a limp mode. I am not to familiar with the 80 , but it could be a sensor if it happens on an incline it sounds like a fluid level. I heard that you checked all the fluids . coolent ? brake,?
What year is the 80? A440 or A442 tranny? That will determine whether or not you have a TPS. That said, no 1HDT is electronically controlled so I can't see why it wouldn't rev passed 1200rpm even if your TPS was malfunctioning. The TPS sends a signal to the tranny ECU and doesn't control engine speed. I suppose if the TPS was telling the tranny to put itself in the wrong gear it, i.e., top gear, it could cause it to bog badly.
I would be looking at a fuel supply/ filter blockage.
1993 model
I would eliminate the fuel lines and fuel pick up 1st.
There might be something like piece of plastic in the tank wrapping around the fuel pick up on an incline.
1993= A442 electronically controlled tranny w/TPS.
Throttle position sensor.
I'm not sure that is the terminology that Toyota uses on the 1HDT but it is essentially a sensor on the throttle linkage of your injector pump that lets your tranny know what gear it should be in.
Mac, would that only be affected when on the incline?
I personally doubt it but stranger things have happened. I only raise the TPS issue because it was mentioned earlier by other posters as having caused issues with other vehicles- I think a Nissan Patrol was mentioned. Maybe just check it for proper adjustment and make sure it is secure and the plug contacts are ok.
I, as I stated before, would be looking first at a fuel supply issue. Check your fuel filter. When you experience this issue again, pull the fuel line to the injector pump and see if you can hand pump a good quantity of fuel using the hand primer on top of the filter. As Rosco mentioned, you may have something in your tank. Any enemies??;)
It's the TPS the Black part over the IP with blue letters Toyota / Denso ?
main.php
IT looks similar to the TPS on the Patrol:
There are quite a few threads on Outerlimits4x4 of TBS faults causing similar problems in both Toyota and Nissan diesels. They all say that the TBS also controls the butterfly valve's opening and closing. I have no first hand experience with it. only repeating what i have read. I asume the quick test is to observe the butterfly valve on the intake when Busted100 has the problem. If he can't bring the revs past 1200 when sitting on the side hill and the butterfly remains closed then I would assume it is probably related to the control mechanism of the butterfly valve. But there must be another way of testing if the TBS is working properly. I just don't know it...
