L diesel in an 89 4runner
New Jersey
would an L diesel engine in a 1st gen 4runner be too underpowered for highway travel? how difficult would it be to turbo the L as far as finding the correct manifolds? with a turbo, would it have enough umphh? is turbo not enough? what about tweeking the motor another way to gain some power? any help is appreciated...thanks!
- doug
I thought it was way underpowered...but mine was also using 5 qts of oil every 500 miles :eek:
1kzte would be a much better choice...
bk
Get a 2LT-E basically the same as the L but already turbo'd. The L series is what the rest of the world got when they ordered a diesel 4Runner/Surf.
L
yea, i know there are a few other options, but i found an L for way cheaper than the others, and i was wondering if it would even be worth it to buy and maybe tweek a bit to gain some more power
The money and time you spend tweaking it would be better off invested in something that is already tweaked at the factory.
If you do buy this L engine,make sure the pump is functioning as it should and the compression is good on the motor.
No one gives away good diesels cheap;)
