When you converted to manual hubs, did you replace the knuckle housing? If so, how did you figure out the shims, or did you reuse your shims?
No, I did not replace the knuckle housing. I have had them off previously to clean/paint and replace king pin bearings, but I just put the shims back as they were.
If you do need to replace shims, just follow the factory service manual instructions. There is an SST, but I believe that is discussed on these forums somewhere and someone describes a DIY setup.
