Kzj78 control arm bushing questions?
SoCal
To Kzj owners with coil spring suspensions. Does the control arm bushings on a kz prado the same with the 80 series? The reason I ask is that my brothers Kzj 78 control arm bushings for the front and rear are messed up and I was wondering if it is the same as the fzj80 series bushing. He is also in the Philippines while I'm in the USA and we only have the 80 series for me to base on for parts. Thanks.
:cheers::beer:
Cary
Not sure about the FZJ80.
But these ones are all the same.
The two bushes which mount to the diff that is (and rear arms).... its sized with a bolt hole 16mm and sleeve 50mm. Big outside diameter of 60mm and 40mm wide.
Don't replace with nolethane ones as they will not flex as much as the rubber and will tear out.
NISSAN Patrol Y61 Series GU Wagon / Safari 12/1997 - 2006
TOYOTA Landcruiser 105 Series Solid Axle Front Suspension 6/1998 - 2007
TOYOTA Landcruiser 78 Series, Troop Carrier Wagon & 79 Cab Chassis Ute 10/1999 - 2007
NISSAN Patrol Y60 Series GQ LWB & SWB - Safari 2/1988 - 12/1997
TOYOTA Landcruiser 80 Series, Wagon 5/1990 - 3/1998
TOYOTA Landcruiser 73 Series KZJ73 MWB Mid Wheel Base, Landcruiser II 1990 - 2002
TOYOTA Prado 70 Series LWB & SWB 1988 - 1995
TOYOTA Landcruiser 71 Series HZJ71 SWB Short Wheel Base
TOYOTA Landcruiser 74 Series HZJ74 MWB Mid Wheel Base
You need a press and tool to get them in and out.
Calvin
