Builds 'KRIKEY' (stevesnj) Build thread (4 Viewers)
Used herculiner around the drawers instead of polyurethane wood to make and grease or grime less noticeable. Good contrast with the stainless steel drawer fronts. :]
Made an extension to the drivers side of the rear deck to gain more space for a sleeping area. Worked great with a sleeping pad and sleeping bag. Slept great at the Coal Mine Cruiser Classic 2015. Don't need to buy a tent!!! Woo hoo!!
Got a deal at autozone. 10 globe LEDs for $15. Put 3 for the license plate and put 4 in the door lights.
Bent the drag link on my last wheeling trip so I got the 1 ton TRE and dom tubing from ruffstuff. I think it shouldn't bend anymore :]
Great time camping and wheeling at the CMCC 2014! KRIKEY got trough some rough spots I never thought he'd be able too. Also had a nice dinner and won an LED lightbar from Toytec! Thanks Toytec !
Very easy install. Just mounted it today and gonna wire it to one of the Toyota OEM fog switches when I have a full day.
Yeh this thing is killer bright...wow!! The sunroof sunshield was open and it lit the inside up too. :smokin:
did you essentially just use tool chest type drawers on your rear box? do you have any rattling issues?
Yeh a Lowes Kobalt tool chest, it was made poor and fell apart but the drawers held up. I took off the old sliders and put on self closing slides and they keep the drawers shut. As far as the rattles I have none, I used foam cutout materials for the most used tools and tool roll ups for other tools.
Installed Ruffstuff 1 ton tie rod ends welded to some thicker than stock DOM tubing, the DOM they sent in the kit would of hit the bottom of the pinion output oil shield. So I had to get a thinner wall DOM. Now to try and figure out how to center my steering wheel...ugghh
Had to drill out the knuckle to fit these monster TRE's, 7/8" drill but and that was it.
The tapered insert
These inserts fit perfect and the bottom went flush. Great job these guys did making these inserts
The monster TRE
The thinner DOM tubing, closer than it looks, the original DOM wouldn't of cleared
Coming together nicely Steve. Subscribed.
Where in NJ are you?
Been a few months but got a bit done. Just been taking a long time to install stuff and still need to finish some things.
Originally when I installed my drawer system I integrated a space at the end for subs. They were old home theater system subs but they worked great! then taking one of the subs out I stabbed the foam surround and that was it. So due to the limited space I got 2 Rockford Fosgate 8" DVC 4ohm subs model P2D4-8. http://www.rockfordfosgate.com/products/details/p2d4-8 They work great!! I adjusted the amp with a multimeter and it is amazing how well it sounds when adjusting it proper. I can turn it up to max and no clipping or distortion. Anyway, they were so close to gether and I had no room to move them further apart, but I contacted RF and they said the magnets being so close doesn't matter. But the grill rings were gonna hit each other and I dont have a welder so i cut and shaped and SteeSticked it and epoxy. Once I paint it it won't look great but still an original look..lol
I was going to put vents in the corners but I hit the frame of the drawer system, so I am gonna cover them with a small tweeter grill to finish it off and it will vent a little. I have two vents on the sides of the subs. $120 for both at vminnivations.com
So I started all this because my stock radio made a noise and then it just died. So I bought a Kenwood DX271. It has just what I need. Two camera inputs and preamp outs for he sub. Wiring is what took the longest, I removed the factory amp and used the bypass wires for everything else, speakers,power, etc. I soldered and heat shrank all the wires. Pre Wired all the cabling for the rear view camera, and i put a free cam I picked up, at the front right so i can see what I will be driving over. I also angled the right side of the HU because it was just too flat and had to lean a little to see some stuff. ll I did was use 2 3/4" tall nuts and longer screws and its now easy to see and angled and looks good angled. I was happy when my iPhone 6 worked with the HU.
After a week of using it the front speakers just couldn't take it so I picked up a set of Infinity 6502ix Reference Series with adjadjustableeeter. So I can turn the tweeter away from the side of the dash towards the passenger and driver. Works amazingly well. Install was a breeze, and someone I know didn't want the DynaMat he had so I used that and there was just enough to do both front doors.
Some more pics
Door cars installed on Passenger side.
Rear camera mounted under the license plate for when i use my dirt bike carrier i can still see when backing up with the view from under the dirt bike motor. Came out good.
Front camera at the front right.
I also installed the 50watt Amber/Yellow 1156 LED's. They are bright and with the side view and front LED signals I am complete in the signal department. Brake and Tail lights next. I got the lights here http://www.aliexpress.com/snapshot/6245061035.html but Im sure you can find them elswhere. $27 with free shipping. Took 2 weeks to get. Have a vid I took during the day.
