I need some shock schooling. I have some questions regarding the "adjustability" of these shocks and shocks in general.
These Koni Raids are advertised as adjustable - at first I thought that meant adjust the damping from comfort to firm with a knob on the shock itself. (Those exist, right? Just not for Cruisers). After further reading, it appears that while the firmness is adjustable, it is meant as a one time adjustment or very infrequent adjustment (for example your springs or tbars are weakening and you need to adjust the shocks after x years, or you added or stripped off significant weight and need to adjust shocks). Therefore, it is not a simple knob or switch - instead, you need to remove the shock (at least the bottom mount), push it all the way in and turn clockwise/counterclockwise etc... So it's not something you would do b/f going on the trail and b/f getting back on the road. Is this understanding correct?
