Knuckle / Tie Rod Pics....need to R2?
Discussion in '40- & 55-Series Tech' started by TJDIV, Jul 24, 2005.
  1. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    Couple pics of knuckles and tie rods.
    I'm thinking it probably can't hurt to use the rebuild kits I have for the knuckles and the tie rod replacement kit? Steering is developing "locking" points. :eek:
    And the brakes are pretty much dead. Going to try to bleed them, then gonna get with Dan-O Banan-O and get new partz.
    Whaddya'll think?
  2. TJDIV
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    But it's still got character!
  3. andrewfarmer
    andrewfarmer
    799
    1
    Jul 18, 2005
    Wellington, NZ
    Looks like a rebuild is in order...
  4. mallred
    mallred
    616
    Apr 4, 2004
    It looks like there is water in the knuckle to me, you might want to check the front diff oil.
    It might be the birfs binding.
  5. cardinal fang
    cardinal fang
    786
    1
    Jul 13, 2003
    Folsom, CA
    That's ugly! Rebuild for sure!!
  6. HawkDriver
    HawkDriver
    3,308
    Media:
    66
    Albums:
    5
    100
    Feb 1, 2002
    No. Ogden, Utah
    That shizz is nizzassty fo shizzzooo. Clean that crap up man before someone from the EPA sees it and cites you. :D Replacing the knuckle bearings will definitely help with those steering locks. Did that only once, kind of neat job to do, I thought. But even after I replaced the seals that are going bad in that pic they started to seep again after a year or so. Have fun wit it.
  7. nuclearlemon
    nuclearlemon not an addict Moderator
    16,253
    Media:
    87
    Albums:
    4
    1,108
    Jan 30, 2003
    meh-ico, colorado
    definitely in need of a rebuild...it's nice to be able to turn when you're done ;)
  8. TJDIV
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    Well, since time, and tools are in short order around my place I may end up "shop dropping" it. However, I know I can do it if I do come across the time.
    What tools are needed for the knuckles? [outside of regular garage/shed stocked tools?]
    Thanks. Tom IV
  9. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    My knuckle rebuild.
    Well it's a little more than just a knuckle rebuild. :D
    [​IMG]
    Cut and turn is in order.
    Took me 2.5 hrs to get this far.
    definetly need a socket for the hub nuts. I think 54mm but they a different size earlier years.
    http://www.sor.com/sor/cat200c.tam?xax=18401
    and a good socket set.
    Brass drift $5
    seal puller $9
    c-clip pliers $18 (not necessary but nice)
    Hammer
    Crowbar
    screwdrivers.
    alllen wrench (maybe)
    rebuild kit with knuckle bearing with races
    a tub of good bearing grease.
    good toilet paper
    and the ability to visit the tech section of Mud to know what you are doing.
  10. nuclearlemon
    16,253
    Media:
    87
    Albums:
    4
    1,108
    Jan 30, 2003
    meh-ico, colorado
    hhhhmmm...i got by without brass drift, or nut (did it the old fashioned way with screwdriver and hammer, cause i didn't have a 54mm at the time). you can use the screwdriver as a seal remover and a couple to pull the c clip, but plan on being there for a real long time. basic hand tools can do it. remember to keep the shims in same locations or plan on a fish scale also (about $5).
  11. HawkDriver
    HawkDriver
    3,308
    Media:
    66
    Albums:
    5
    100
    Feb 1, 2002
    No. Ogden, Utah
    I tried using the same sized shims when I did it and still ended up having to take em off a couple times to get it right. I also just used my calibrated arm to measure a little tention. As long as it's not binding tight or sloppy loose it should be in the neighborhood.
  12. dgangle
    dgangle total rice
    4,002
    20
    Nov 24, 2004
    Heart of Dixie
    So what is your question?
