Knuckle Rebuild/71 FJ40/ Re-Assembly/ Upper and Lower Bearing Retainers Extremely Tight (1 Viewer)
Disregard. Little heat as mentioned above and circular wire brush the same size of the hole did the trick...
For those who encounter a difficult bearing retainer, try using the 1.5" wire wheel from Harbor Freight. Run it up and down in the hole a few times and then hit the retainer post with some emory paper. The wire wheel seems to heat it up enough to make easy work out of it...
