So I'm swapping FJ62 knuckles onto my FJ40. I used the proper FST to measure the necessary shims... I checked my measurements and math 3 times - but I could still be wrong.
I am using all new bearings/races, shims, cone washers and nuts - all from Toyota.
Now that I have assembled the knuckle onto the housing and tightened the nuts to the high end of the recommended torque range (that's the kinda guy I am) I am getting basically zero preload... There is no resistance when I turn the knuckle side to side. BUT there is also no play, wiggle, movement of any kind that I can detect in the bearings.
If I used too much shim the preload would be too low... right? But at some point I should get play in the bearings... right?
I am going to check the math again but in the mean time any ideas/thoughts?
mark
mark
