knuckle preload, shims...
Unfortunately each is different. Someone had on mud a good way to fab up the tool used to measure the distances you need to know to finish this job. I bet a search on mud for SST 09606-60020 would yield results for a way to fab this up.
Each housing is set up at the factory and each is a little different. You need the tool to re-figure it out if you lost track of where the shims go.
