I needed to come up with a quick and simple knuckle bearing separator tool, using something I already had in my shop. So I used a turnbuckle. I removed the right-hand threaded hook part, and replaced it with a short piece of threaded rod that I had ground to a sharp point (wrench included for scale):
I kept the left-hand-threaded loop end in place. I stuck it between the center points for the bearings, and turned it with a wrench. The point keeps the top centered, and the curvature of the loop keeps the bottom centered, better than I had imagined it would, it actually works quite well. I used a long phillips screwdriver through the loop to keep the bottom from spinning. The threads on the top point were bunged up enough from the grinding to prevent it from spinning in the turnbuckle, plus I was turning the body in the direction that would have extended it anyway, so it still would have worked, I think. Note that I left one or two of the bottom bearing cap nuts on to keep the bearing from just dropping to the ground:
Once one of the bearings let go, I put the knuckle on the bench and used a large fender washer as a base to push out the other bearing.
This took me about five minutes to fabricate, and it worked great right off the bat:
