Knuckle bearing installation (1 Viewer)
Oakley40
Oakley
I am installing new knuckle bearings and I'm having problems with the lower bearing sliding on to the bearing cap. The bearing slides on the steering arm cap nicely, but not the lower cap. I wire wheeled the cap to smooth any burs, but I still can't get it on without forcing it.
Is it okay to tap it (on the inner race) in place?
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
Technically, the bearings are not supposed to be a ‘slip-fit’ on the trunnion pin of the steering arm or lower knuckle cap; they were a ‘press-fit’ from the factory.
:meh:
There's a tool for that. Essentially, the tool holds the bearing in place and uses the bottom cap and steering arm as presses as you tighten the stud nuts. Like Poser said, it's a press fit.
Oakley40
Oakley
Another knuckle question....
Thanks for the help guy's. I appreciate it.
Another issue...I'm slowly (very) putting on 60 series knuckles on my 40 and I don't have enough outer axel showing to put the c-clip on. I tried putting a screw in then end and pulling on it, but no dice... still not enough. Any ideas??
Poser
s-Moderator
Supporting Vendor
MN
Pictures...
What lock outs have you installed?
Oakley40
Oakley
The lockouts are Aisian's. I'll post up some pics when I get home.
Oakley40
Oakley
Can't get the outer c-clip on....
So here are some pics of the Aisian hub and how much shaft I can get pulled out. Like I mentioned above, I put an eye bolt on the end of the shaft to try to pull it out, but this is about all I got.
Any help would be appreciated!!
LCS
Which birfields are you using? Without pulling some birfields from inventory to check, I believe the 60 series are a bit longer than the 40 series.
kurtnkegger
Running Topless and Dirty
Denver, CO. Burbs
Bridge something over the lockout housing, and run a bolt down the threads. The bolt will pull the birf out a little, and get you the space you need.
Poser
s-Moderator
Supporting Vendor
MN
The earlier 40/55 series disc brake axle outers were longer 08/75-12/78.
In 01/79, they all became the same length; 40/55/60/62/solid axle min truck.
FJ60Seth
Altadena CA
Just curious here. What changed in 01/79? The length of the axle shaft?
Cdaniel
Undocumented Mechanic-Not CDAN
AZ
subscribed....
I'm curious about the solution, as I think I may have the same issue with a pair of Aisins I have.
I heard that leaving the snap ring out isn't a big deal, but it doesn't make sense.
Josie'sLandCruiser
Stop calling it a "FJ."
Seattle, USA
Hi All:
For using Warn lock-outs with the 1979-89 Birfields they supply a bolt and fender washer since the snap ring can't be inserted.
But, those look like the post '70 short Aisin lock-outs in the photos posted, so this should not be a concern!
If you don't locate the Birfield at the hub end the shifting back and forth of the CV joint and inner axle shaft will prematurely wear-out the axle seal.
Regards,
Alan
subscribed....
LCS
Maybe I was thinking about the coarse spline birfields, which are shorter than the later fine spline birfields.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
