So i put a new clutch/throwout bearing in about 4 months ago, followed the many write-ups and all went well..sounded good, felt good, no issues.
About a week ago I started noticing a knocking sound from under the stick shift any time I would get to a red light and put it in neutral. As soon as I depress the clutch pedal, even partially, it goes away. I took the inspection cover off and looked around, nothing obviously loose or disconnected. The clutch/flywheel area looks dry and clean. There is some dampness/oil that seems to be coming down the shaft from the front of the tranny (input shaft?).
Watching everything move while the engine runs, I can clearly hear the knocking sound from somewhere right in there but can't figure out if it's in front of the shift fork or behind. As soon as the clutch is depressed and the fork puts any pressure on the clutch the knocking goes away.
Any input on how to further diagnose without spending 2 more days disassembling everything? I feel like I could replace a throwout bearing if needed but don't want to tear everything apart to find out the problem is within the tranny, which I'm not comfortable breaking open and trying to figure out.
Thanks.
Thanks.
