Build Klip's FJ62 revival
Orikawa tailgate panel installed. Didn’t have as much difficulty with the well nuts this time. I dig it.
Ready for some action. I’m gonna gain a little altitude this weekend.
I carry a spare with me but I blew through two tires. I aired down for a smoother ride and revealed all the cracks in the side walls. I was able to do some wheeling before the second tire blew out. Air lockers worked good, black box works great, temps never got above 155. I ended up getting a ride home on my buddies trailer but all in all good trip. Tires move to the top of the list, then sliders.
This is Morris lake trail, one of the more difficult trails. I saw a line and went for it.
Made it out with just a little dent on the right side rocker.
Double low, front and rear locker engaged. That was a lot of fun and can’t wait to go back up there! Camped at Long lake.
Temps running at 155F? Is that a typo?
@Domofthedead @yarncruiser Some of the above photos look like that section of Cascade Creek that Karen and I went down this summer. Cascade might have been a little smaller, but not a lot. I'm glad we had gravity on our side! It's still snow-free up there if you're looking for a weekend jaunt before Moab.
No typo, that’s black box oil temp. Something I’ve been keeping a close eye on. I have a temp sender as close to the black box as I could get it with a gauge in the cab, where the 4 high switch used to be. And a temp gauge in the sight glass on the oil tank I made.
Engine coolant temps are normal. All is well since I put the CSF radiator in it.
It used to be a lot more green up there. Big burn scar in the background is from the Dixie fire 5 years ago.
Nice, I was thinking 155 is awful low for coolant temp and your fuel might not be atomizing the right way, rings not expanding like they need to, etc. Makes sense for the gear oil in the black box though.
The trail I was tagging my friends about is one out here in Colorado that I ended up on alone with my wife - I'm on 33s and unlocked and we came up on this 1/4 mile ledgy boulder field that looked like your photos. I swallowed hard and we made it through haha. I was happy to have sliders that day.
Sounds like fun! I’d really like to get out there do some exploring. The pics you and others posted of SAS look amazing! Maybe get in on an SAS??? That’d be a blast
It's a great time for sure.
Before my camping trip I changed the wiring on my speed sensor. Check engine light has not been on since! I was looking at some old pictures of how the JTR sensor was wired and it looked like one wire out of the sensor went straight to ground. Thought it was worth a shot and changed up the wiring. By gosh, I think I got it! Not too sure why it works like that but I’m not gonna think about it too hard because it works!
1 of 5 tires showed up today.
Falken wild peak MT. 38x13.5x17.
The tires are still aired down so it’s sitting lower.
Still looking at wheels. I ordered one Raceline steel bead lock for a test fit. Checking out other aluminum bead lock options. I think a gold wheel with a black bead lock ring would look pretty slick.
I bought 3 of these Toyota fog light switches. For reverse lights, torque converter clutch, and rock lights.
I wanted to relabel the switch for the TCC so I tried to remove the paint from the switch. I was able to get most of the paint off but the symbol is debossed in the switch so you could still see it. I lightly sanded it down until the symbol was gone. I started with 400 grit, then 1,000 grit. The 1,000 grit made it too smooth, so I hit it with the 400 again to put a little texture back into it. Now I’m trying to think of the best way to label the switch with TCC. A small template and paint it on? Small custom sticker? I remember reading a switch relabeling thread that covered how to do it but I can’t find it.
I made a short harness so the console can still be easily removed. The cab harness is routed under the passenger seat to the passenger kick panel and up behind the glove box where I’ll install another connector and run wires out to the components from there.
I did have to modify the console to get the switches to fit. Not much, just filed the sides of the switch cutouts, the length was perfect though.
Mo Faraz does decals. I forget his handle here on Mud, maybe somebody else will know it
Cool stuff, I have some lights on my bumper, and I would love to wire up to some OEM switches. Another thing for the to do list
Do the reverse lights still come on when in reverse or do you have to manually switch them on exclusively? I have the oddiron led kit and would also like to be able to toggle them without being in reverse.
bet it feels great to have it back on the road. :cool:
The reverse lights are only on the switch in the console. Yea I think it’ll be pretty handy having them on a switch. Just need to make sure I turn them off before I hit the road. The little amber indicator light is pretty bright so that’ll be a good reminder. I also have the ability to blind tailgaters!
It was a lot of fun getting up in the mountains with it. It did feel great, can’t wait to do it again with some fresh rubber!
On a switch will be handy for those jack wagons with the overly bright headlights that like to tail gate.
