Build Klip's FJ62 revival
Ended up getting a new CSF radiator. Unfortunately it got a little shipping damage but it’ll be ok. Other than that it’s a nice part. Decided to put the cooler in the lower tank back to use for the trans. The plan is to plumb oil to the rad cooler first then the external cooler in front of the rad.
The old fittings for the cooler are long gone so I ordered some new ones. The threaded ports in the CSF radiator are different though. The diameter and thread pitch are the same but the original one is cut for an o ring seal. The CSF is not.
The fittings I have are m14x1.5 to -6 AN. I have a couple different ones, with and without o ring. There isn’t a taper cone or anything inside the port, and the threads are too long to thread in all the way. So they really don’t have a way to seal.
To get it to seal I’m going to cut a couple threads off and use these drain plug seals with integrated rubber I just happened to have two of. And probably a drop of anaerobic sealant on the threads.
CSF model number 2708. CSF website says it’s a 3 row, the one I received is definitely a 4 row. The shipping damage is on the fill neck, specifically the flange the outer cap seal seals on. I straightened it out and I think it’ll be ok. Vacuum filled the system. My condenser is in pretty good condition but looks pretty dirty, it’s probably restricting air flow. Since my ac is currently inop I'm just going to leave it out for now.
Radiator installation complete. My trans cooler didn’t work out. The engine oil cooler fitting hit the trans oil cooler fitting.
Now I can continue with breaking in the new gears. And chip away at interior upgrades. Got the center console installed.
I have the tailgate lid and cargo panels to install. All from Orikawa.
Prepping for some work in the back. Pulled out 8 years of chaos. The bottle of bar oil has a hole in it and the carpet soaked it all up. That carpet is completely hammered and will not be going back in.
This cruiser has been such a workhorse cleaning up after the fire. I used it to skid huge pieces of trees, move trailers of lumber for the new house, tow farm implements for ground work, moving trailers… so much. And maintenance wise it was pretty much neglected, but now it’s getting some much deserved love. Orikawa cargo panels and tailgate lid are going in.
Couple irons in the fire. With the new t case setup I lost a location for the vehicle speed sensor. And running without it causes the check engine light to come on. I could simply bypass the PRND switch so the computer thinks it’s in park all the time, then it wouldn’t ever look for vehicle speed and the check engine light wouldn’t come on. But I put a lot of work into incorporating that into the factory fj62 shifter, and I just can’t bypass all of that work. So, I’ve been thinking of how to add a vss. The simplest way I think is to utilize the tone ring on one of the rear axle hubs. Find the right type of sensor, and probably remove some of the teeth on the ring. Old vss is the yellow one, from jtr. Potential sensors I found in the shop, both from Peterbilt semi trucks. A bunch of testing on those to come.
Just need to find a sensor that produces the required signal for the ecm. It needs to see an ac sine wave. The FZJ80 wheel speed sensor produces a square wave signal. Not way too savvy on this but I think I’m going learn a lot. And I need to get this done by the next smog test😎.
Well, I thought the cargo panels would be an easy install and knock another thing off the list. I was wrong, what a PITA. The rubber expando nuts just don’t work that great. The screws that came with the panels seemed too short. I’d have to push on the panels pretty hard to get the screw to the threads of the nut, then push on the screw and tighten at the same time. The nut would just pull through the body. So I went and bought some longer screws and tried again. After a couple hours of trying to get them on I only got 3 to grab and hold the panel on. These rubber nuts are just too much hassle, ordered rivnuts.
Yeah, I went the rivnut route as well. A word of caution is to be patient with them as well. I found they will get out of alignment pretty quickly if install them in a circular pattern. Seems best to keep them loose and install in a sort of star pattern.
I’ve had my panels for 2 years and still have one door to go.
They are a really nice product though.
With my panels that have doors and speaker holes I simply use a M6 bolt, washer and nut for all but 2 of the holes (most forward) those I install rivnuts on. For most of the perimeter you can use U-nut aka "speednuts" and they allow for most all misalignment.
I too agree the well nuts supplied here are a PITA to use and if you have to remove the panel... even worst to reuse.
Did some testing on the original wheel speed sensor. There’s a step up in the wave form and you can see small steps up and down the wave. It’s also kind of hard to get a consistent reading with the flat head bit in the drill. Just want to compare every speed sensor I have.
Does anyone know if there’s a square wave to sine wave converter? I did some googling on that and only found how to build one. If it exists I’d like to buy one and try it out.
Found a sensor that I think will work out for me. Caterpillar part number 318-1181. It’s used on a lot of different CAT tractors, from back hoes to mining trucks and big excavators. It makes the right signal, it’s long enough, and fits in the hole.
This is with sliding a screw driver on a piece of plastic that was really close to the tip of the sensor. It was hard to do all of that and hit freeze at the same time.
Now I need to modify/make a new tone ring. The pick up for the Toyota sensor is off to the side. This sensor doesn’t pickup anything off this tone ring.
Pulled the hub and decided it would be better to make a new tone ring. Designed and cut one out on the plasma table and bored the ID for .002” press fit and used retaining compound.
Modified the speed sensor block off plate I made with a threaded bung/boss/sensor holder.
Installed and tested, and it works!
Still need to finish the wiring. Then test drive.
Sorry I am just now seeing this before you went to all that work - did you try the original fzj80 tone ring and sensor? I have been using them as-is with my GM swap for 8 years now without issue :(
No worries Matt. I did try the FZJ80 sensor but I didn’t think it would work for a couple reasons:
- I was thinking it might be too many pulses. The VSS I was using was the JTR inline speedo cable sensor. And only has 2 pulses/rev.
- The FZJ80 sensor produced a different signal and I wasn’t sure if it would work. It was a wave of sorts but looked different on the scope.
Not 100% sure if either of those matter but I know what I had before worked. So I wanted to get as close to that as I could.
While I was at it, I hit 500 miles on the new gears. Changed the rear differential oil, mag looked good. Changed the trans oil and filter. Installed a new trans pan and the original temp sensor/switch. I also replaced the trans shifter shaft seal, it was leaking. Took it for a 10 mile test drive. It looks like that took care of the trans leaks but unfortunately my check engine light came back on. Haven’t verified it’s because of vehicle speed yet but I’m assuming so. That was the only code that was stored before. So I need to do some more testing on that.
I made the adapter for the temperature switch. Got a used switch from Cruisermatt. Now my trans temp light on the shifter console is functioning. Before it was just on all the time. I was just going to use a NC temp switch but when I jumped the terminals in the connector the light still stayed on. So there’s more going on there than just an open or closed circuit. I checked the resistance of the Toyota switch I got and it was 2.5k ohms. I’m not sure where the trans control computer is but it’s using resistance to control the light. The schematic calls it a sensor, the Toyota parts guy called it a switch.
Gettin’ there! One more list to go!
