Hi,
A month ago I bought a four cylinder automatic Prado with a 2.4 EFI turbo deisel which I have since learned has some issues with overheating. I took it up to Weaver Lake and the gage was climbing. The block is not cracked and everthing seems to be in working order. I want to keep it that way. Have you any suggestions as to what I can do to keep the Prado cool and not have the block crack in the future. I want to take preventitive action. Please keep it simple and specific for I understand very little as to how it all works. However, I am enjoying the ride and want to do what it takes to keep on keeping on. Thank you in advance for your advice.
Update on this post.
My cooling system has a modification that they did in Japan. There is a hose that they have taken from the radiator to the back of the engine. It must work because I took my Prado into a radiator shop. The radiator was 60% blocked. Not only that but I drove to from Vancouver to Kamloops with a little less coolent then I should have had in the system. The radiator leaks, and I was not smart enough to know that the fill tank is not the only guage of whether you have enough fluid. Anyhow, the head on my Prado is not cracked. I can only think that it is thanks to the modification. I am getting the radiator rebuilt, and also having the air conditioning unit which does not work removed. I then plan to have a fan with a toggle switch for extra cooling put in the place where the air conditioning is now. I may not need it, but I would guess that it might still be usefull for driving mountain passes at highway speeds. Well, as close to highway speeds as I can get.
I have learned that it is good to take it out of overdrive when climbing and to put it into a lower gear.
Thank you for the great advice.
