Keepslant 4-link rear suspension conversion
Bay Area, CA
Discuss...
Is the control arm located towards the front of the axle of the centre. I could see an axle wrap issue with both the control arm in the centre and the coil in the rear. Plus, I only see one control arm, hence, this would do well on the rocks. I definitely like the bracket which bolts to the frame.
Looks way better than springs butttttt.........
Those short ass links would make for bad rear steer and not sure about squat, you should post it in hardcore and let the boys rip it apart.
Otherwise way cooool.
Silverscout, if you look closely at the second picture, you can make out the control arm that looks like it is attached to the original spring hanger. 4 links in all.
I have noticed there is no panhard rod , I like the fact that everything is "BOLT ON" I like the coil overs
my 2cents I would use one trailing arm like the 80 or prado and have it threaded like the Keep Slant kit with the coilovers and panhard rod but then it wouldnt be a complete bolt on ,brackets on the frame and axle and frame would have to be welded on , the K/s kit is easier because it is bolt on
Aaron Kuit
