KDSS with 285/ 65 R-18 KO2s
MA
Apologies if this topic has already been covered. I searched and couldn't find any relative info.
Anyone know if jumping up to 285/ 65s from 285/ 60s on stock wheels could negatively affect the KDSS? I'd like to go with 285/ 65 R-18 KO2s, but I don't want the additional ~2" of wheel diameter to have an impact on the KDSS. Also, curious if the bigger load range of E on these tires will be a deal breaker. Could step down to load range D on the 285/ 60 R-18s, but the tires wouldn't fill the wheel well nearly as well. Thanks!
KDSS will not be impacted at all by going with that size tire. KDSS is only impacted when you have a lift large enough that you have to modify the stock stabilizer bar setup.
285/65-18 is only an inch (1.1) larger in diameter than 285/60-18. The speedo will be off a bit (reading 1-2 mph low), but that small a diameter difference won't affect the suspension.
